Hi everyone!
I'm struggling with a huge problem. If I want to open any .step or .stp in Creo Parametric 2, what has circular chamfers in it and was exported with Fusion 360 it simply falls apart. I've made an examle project to demonstrate what actually happens:
This is the design in Fusion 360:
If I export this in .step or .stp and open it in Creo parametric:
You can see that the circular chamfers failed to generate, unfortunately it happens every time, I export in step format.
We tried to "trick it" with edge fillets (it didn't work):
If I export the same design in IGES format it works perfectly. The only problem is, that IGEs files are bigger than step files, I rather use step instead of iges.
Please help me solve this issue!
Best regards,
Laszlo Galantai
