Static Stress Test for Topology Optimised Part
Hi Guys,
I am using topology optimisation feature to reduce the weight of a part. The result from topology optimisation is in pink/purple after I promoted it to the design space. I wonder if I can straight start a new static stress simulation on this pink/purple part, or do I have to sketch a new part based on the pink/purple part in the design space and then run the simulation?
Thank you for your help!
Output from topology optimization/shape optimization will be a mesh body. Based on that mesh body (pink/purple output) one neeed to edit original part then you can go for static stress analysis on that edited part.
