I'm performing static analysis on a file that has a couple of Drawn Cup Needle Bearings inserted in it. Each of those components contains lots of contacts!
A few observations:
1) Initially I generated Automatic Contacts & the default setting was Bonded. That was obviously not a good strategy so I switched the default to "separation and sliding" but then regenerating Automatic Contacts didn't change the type. Discovered was unable to delete the automatic contacts. So instead used UNDO to step back in time. Then changed the default Automatic Contact setting once again. And generated Automatic contacts once again. Then OK.
2) Having set all contacts to "separation + sliding" obviously want I want / need to do is to step through them all to find those that should be set manually to "bonded" or other. However stepping through is a total nightmare. You can't select the top one in the list and use the arrow key to cruise down whilst watching to see what's highlighted in the model. Nor can you read a meaningful contact description in the list. You have to mouseover each contact in turn and read the text / scan the model. Virtually impossible in a large list.
Personally I'd like to be able to select a component and then see just the contacts that relate to that component in the list. That would make things much more manageable.
Indeed in the present model I feel unable to check whether I've got all the contacts "right" or not.
3) Sometimes one runs a static analysis having ONLY changed, for example, a load parameter. Nothing has changed in the CAD model. So it's kind of annoying to have to sit through a lengthy generation of the mesh.
