Starting with flat pattern, then making into 3d
j_y_de_laat
Message 1 of 12
j_y_de_laat
Im trying to model a cardbox box in 3d using fusion. For this I thought the sheet metal interface would be nice, since it is essentially the same thing. I already have a 2d flat pattern (custom) on paper/different software. I just want to draw it in 2d, and let fusion make it fold it into 3d. But I cant seem to get it to work. I have tried looking online for documentation but have been unable to find anything that goes 2d->3d instead of the other way around.
Would anybody be able to help me? Or point me to some documentation about this. Many thanks!
Replies (11)
Message 2 of 12
stropkat
Community Visitor
Community Visitor
Hi, this is not possible in fusion. You maybe can try other CAD software like solidworks.
Message 3 of 12
TheCADWhisperer
@stropkat
Uhm, where are you getting your information?
I have done many cardboard boxes in Fusion.
Message 4 of 12
TheCADWhisperer
@j_y_de_laat
Can you Attach image examples here?
Be careful where you get your information.
Message 5 of 12
j_y_de_laat
Unfortunately I'm not allowed to share the actual design, so I made this to illustrate my problem. Say I have a sketch like this, with parameters a,b,c.
How do I start out with just a 2d drawing, where I draw the bend lines myself (obvious where they need to go for a box). I do not want to first draw a 3d version as it is quite complex. When drawing this in "Sketch mode", and Extrude it, all of the interior boundaries are immediately lost, and thus I need to draw all of them again as a bend line? The bend function seems to work terrible in general.
Message 6 of 12
TheCADWhisperer
This is easy, but if you can't Attach your attempt, I can't help.
Maybe someone else can jump in here.
You should be able to create a dummy file that does not release any proprietary data.
BTW, for an experienced user it is actually much much easier to model the box in finished form and have Fusion figure out the Flat Pattern than to go from a Flat Pattern and fold it up.  I guarantee this. I could demonstrate with your actual geometry.
Message 7 of 12
laughingcreek
some place to start.
Message 8 of 12
Warmingup1953
Are you starting with a Pepakura Designer type of output?...not as simple as your Cube laid flat?Screenshot 2025-01-29 053921.png
Message 9 of 12
j_y_de_laat
Hi! Thanks. This is exactly what I want. I'm trying to look at your example to see what you did different (Im sorry but I'm not very experienced in Fusion). You use the flange tool as the second step, but when i try this all my interior lines disappear:
Then, using Flange:
After which I cannot use the bend tool, since it does not recognize any lines.
Message 10 of 12
laughingcreek
turn your sketch back on.
while you're at it you might want to deselect this setting in your preferences-
Message 11 of 12
j_y_de_laat
Thank you so much! I can't believe this was it. So simple.
Message 12 of 12
TheCADWhisperer
@j_y_de_laat
Unfortunately, it isn't so simple.
The results don't make logical sense.
(Actually, it is simple if modeled in finished form.)
