springload function?
et.teljemo
et.teljemo
I am wundering if there is a way to get i springloaded funktion on joints...
So when I push something and then realese it pops back.. och if I push a button it releases something to move.??
TrippyLighting
What you are describing is sounds like the rest position.
You'll have to right click on the joint in the browser and select edit joint limits. That includes a rest position the joint snaps back to if you release the part.
et.teljemo
@TrippyLighting Thank you..
et.teljemo
@TrippyLighting
It doesnt work as I want it to 😞
It works as it is intended I guess but I would have loved for a piston to stay behind a obstacle after releasing the mouse button until I remove it..So I could simulate a spring loaded mechanism..
I did this test model http://a360.co/2l2w225
