Announcements
Spring support in simulation
info7JY2S
info7JY2S
is there a way to model a axial spring support in simulation mode?
example:
I need a simulation that uses an axial lineair spring as a support. However, I can't find a way to simulate this spring type constraint.
To clarify: I DON'T WANT TO PHYSICALLY MAKE A 3D MODEL OF A SPRING. reason is that I want to be able to "play" with the "k-value" to find an optimum. Modeling a real spring makes this a lot more time consuming.
Most FEM programs I'm aware of have this option
TheCADWhisperer
Pinging @shekar_sub @John_Holtz
John_Holtz
Autodesk Support
Autodesk Support
Hi @info7JY2S
Fusion simulation does not have springs support.
If you do not have access to a different program and had to do it in Fusion, I would make a simple rod. The stiffness of a rod in compression is A*E/L, so you can change any of those parameters to get the stiffness you want for different iterations.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
info7JY2S
To bad there is no function for a spring support in fusion. But so far this idea looks like reasonable work around. thanks.
