Splitting Errors
Splitting Errors
Naman__Dharmani
Splitting Errors
Naman__Dharmani
I'm trying to split the cockpit of my Airplane to make the windows, but it for some reason shows
Error: Split3
Compute Failed
No Intersection between Targets and object
Autodesk Fusion 360 (Personal - Not for Commercial Use) 23_10_2022 11_47_28.pngAutodesk Fusion 360 (Personal - Not for Commercial Use) 23_10_2022 11_47_36.pngAutodesk Fusion 360 (Personal - Not for Commercial Use) 23_10_2022 11_47_51.pngAutodesk Fusion 360 (Personal - Not for Commercial Use) 23_10_2022 11_47_58.pngAutodesk Fusion 360 (Personal - Not for Commercial Use) 23_10_2022 11_49_28.pngAutodesk Fusion 360 (Personal - Not for Commercial Use) 23_10_2022 11_49_45.png
dsouzasujay
Hi @Naman__Dharmani
I think the split is not working because of the body curvature, but not sure.
If you want to just cut the body, then use the Extrude Cut.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Bunga777
Because only this sketch fails, there must be something wrong with it.
Split worked fine with a similar sketch in the same location.
When the sketch was written, there must have been some inconvenience.
Naman__Dharmani
Actually I want to split the body to create a new one, to give the cockpit some details
Naman__Dharmani
That somehow helped, I guess I made some errors while creating the sketch
Thank You @Bunga777
