- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a top-level assembly (a box) that has the lower part, the upper part, the hinges, and the latch all as components brought in from their respective design files. I now need to set up the top and bottom parts of the boxes at a 45 degree angle with respect to ground for 3D printing.
I can't just print the original components as modifications were made to both in the assembly, such as cutting the two bodies with the hinge bodies and latch bodies.
How do I go about making a version of each part of the box with their required support and sprues without losing connection along the design chain?
I do not want to rotate the part in the slicer and leave it to the slicer to add support.
Below, you can see the two parts, top level assembly, and how I add support for the slicer.
