splitting a sphere in half
widpyro
Message 1 of 20
widpyro
Im new to fusion360 and Im trying to split a sphere. Ultimately I want it to be hollow with a wall thickness of .0625. How do I halve a sphere?
Replies (19)
Message 2 of 20
davebYYPCU
Draw a line in a sketch from the sphere centre point.
Shell the body with that wall thickness.
Split the Body with the line you drew.
Remove one half.
Might help….
Message 3 of 20
widpyro
Can you elaborate on "draw a line from the center point"? I have placed the center point, but cant seem to get any further. Im new at this..  thx
Message 4 of 20
davebYYPCU
If,
you have the sphere on the document origin, you may be able to use the document plane, of your choice, to Split the Body
Otherwise, you create a sketch, the line can be placed at any angle.
The split will be as you look at that line, one half on each side of the line.
Might help….
Message 5 of 20
jhackney1972
Another way to split a sphere exactly in half is to use the Silhouette Split Command.  The video will show this method.  Model is attached so you can look at the timeline.
(view in My Videos)
John Hackney, Retired
Message 6 of 20
widpyro
thank you very much for that tip!  I cant seem to locate the pull down menu that appears on the left on your screen. Where I select halves? What am I missing?
Message 7 of 20
widpyro
Never mind, I git it. sorry for the stupid question. I REALLY appreciate your help.
Message 8 of 20
widpyro
Ok I was able to split the sphere. Now I need to make it have a .0625" wall and trim .125" off the bottom and add a small flange around the interior of the base of the hemisphere. Can you kindly tell me what tools to use?
Message 9 of 20
jhackney1972
I have attached a model of what you describe except for the flange.  You asked for it to be on the "interior" of the base with makes no sense.  Did you mean exterior?
Message 10 of 20
widpyro
The "flange" starts on the edge of the hemisphere and will go inwards towards the center. It should be about .75 inch wide and as thick  as the hemisphere wall.  In other words it is a circular "washer shaped" disc that fits the base of the hemisphere.
Message 11 of 20
widpyro
And the hemisphere should not have that flat spot at the top. Id also ask that the flange be .125 thick instead of .0625 which is the hemi wall thickness.
Message 12 of 20
jhackney1972
Before I misinterpret your design again, please attach a picture or hand sketch of what you "really" want.  It is a waste of time to keep guessing using your description.
Message 13 of 20
etfrench
Easiest way to create a hemisphere with a bottom flange is to revolve it.  Simply draw a circle, offset it, then add two lines for the flange:
ETFrench
Message 14 of 20
widpyro
here is a sketch of what Im trying to o
Message 15 of 20
etfrench
See message #13😀
ETFrench
Message 16 of 20
widpyro
Im sorry but could you be very specific with instructions? I'm at a loss here.
Message 17 of 20
davebYYPCU
Draw a sketch that is the same as Ed’s red sketch outline, with your dimensions.
Use the top vertical line as the centre line.
Use the revolve tool, select the profile, select the top vertical line, as centre line.
Press Ok.
Message 18 of 20
widpyro
Im trying to understand what your saying. Ive created the circle but when I pull down "modify" the revolve feature is not listed.
Message 19 of 20
jhackney1950
The Revolve command is a "Create" menu option in the Solid menu.
Message 20 of 20
etfrench
It's pretty straight forward.  I'd recommend going through the Learning videos at the top of the forum.
(view in My Videos)
ETFrench
