Splitting a circle into equal segments
cruceru.malin
Message 1 of 9
cruceru.malin
Hello!
I'm trying to design a cicle segment and i have some issues on it
The segment has the following dimensions
- rectangular cross section of 6mm by 6 cm
- inner radius of 140 cm
- outer radius of 152 cm
Now,i can create the circles(concentric) and extrude them to thickness but i don't know to divide the result into 5 equal segments and delete 4 of them to be left with only one segment.
Any help is much apreciated!
Replies (8)
Message 2 of 9
g-andresen
Please show a picture of what you want to achieve.
günther
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
Message 3 of 9
cruceru.malin
I've attached the f3d.
I want to split the circle(ring) into 5 equal section,then isolate one of the sections for cnc milling from OSB
Message 4 of 9
jhackney1972
You probably want to create a circular sketch pattern of 5 segments and then use the Split Body command to create one segment.  I think I am interpreting you correctly.  Model is attached.
John Hackney, Retired
Message 5 of 9
jhackney1972
I did not notice the Radii callouts , here is the corrected model.
Message 6 of 9
cruceru.malin
@jhackney1972 can you please give me more details about how have you done it?i would like to learn as well rather than have the work done for me.
Don't get me wrong,it's super helpfull!Thanks a lot!
Message 7 of 9
jhackney1972
I am totally confused on your required dimensions.  Your specs in your post say centimeter Radii, your Circle model you attached in millimeters and it is showing your specs as diameters but no matter, the process is the same.  Take a look at the Screencast.  By the way, you can always learn any process someone used to create a model by dragging the timeline backwards and move one step at a time forward.
Message 8 of 9
GRSnyder
This would be easier to generate with Revolve. Just sketch the cross-section and revolve it by 360/5 degrees - no need to fuss with splitting up anything.
Message 9 of 9
chrisplyler
Any good reason not to model just the fifth you need?
https://knowledge.autodesk.com/community/screencast/0488476f-db26-46a1-8068-2ba1d71b918d
