Split Tool
Split Tool
rafaelpradosantos
Split Tool
rafaelpradosantos
Hello everyone. I'm having problems with the Split Tool, it's not cutting on any other direction, it doesn't matter where I create the splitting tool, always go to the same direction. am I missing something?
Thank you.
laughingcreek
when using a sketch element as a tool, split direction will always be perpendicular to the plane the sketch is on. (in the same way extrude is always perpendicular to the sketch plane the profile is on)
TrippyLighting
To add to @laughingcreek's post, if you want to keep the sketch, you can create a construction plane-at-angle on that sketch line and use the plane as the splitting tool.
TheCADWhisperer
