Split screen - open two models parallel
Maaaaartiiii
Maaaaartiiii
Hello together,
is it possible to open two models and make a split screen that you can compare the two models instead to switch between taps?
Kind regards
  • UI
TheCADWhisperer
I think that the best you can do is have parallel sessions of Fusion running at the same time.
Ajay_Kumar_Reddy
Hey @Maaaaartiiii,
Just insert the design from the data panel by simply dragging and compare the result when you are done. Then delete the one you bought(or hide it for future comparison)
