split body - no intersection between target(s) and split tool
mandreko
mandreko
I'm fairly new to Fusion360 still, and trying to make some stuff for the wife. I can't seem to get a push-pull to cut through my bodies properly. In the attached example screencast (source file also attached), you can see that it cuts through the top surface fine, however does not cut through the curved part of the body. I'm not sure how to get it to go through there entirely.
jeff_strater
Sorry, @mandreko, but it looks like the screencast did not get attached.  You have to hit the "Insert" button to get it actually inserted in the post (which is confusing to all of us).
I looked at your model, and made a guess at what you are trying to do.  If this is what you select for the Extrude:
Then it seems to work OK, and cuts through the model:
If you can find that screencast, I'd be happy to take a look at the problem!
Jeff
Jeff Strater
Engineering Director
mandreko
Ah, I missed the "Insert" button. Sorry, I'm new here. 🙂
Here's the screencast:
It's interesting, I swear I was trying to use the Cut option, and it just wasn't cutting through the bottom side of the arc properly. It would terminate early, at the beginning of the curve. I'll try again, matching your settings. Maybe the screencast will also show what I was seeing better.
laughingcreek
your not selecting the lower portion of the profile. see pic-
jeff_strater
Thanks for the video.  Yeah, if a picture is worth 1000 words, a video must be worth 10,000...
I see what is happening. You selected these regions to cut:
But Extrude (which is what Press/Pull calls for a profile selection) only cuts straight back, normal to the sketch plane.  As the body curves away, that region will stop cutting.  You can see that if you look at it sideways:
which is consistent with what you showed in the video.  Looking from the bottom:
you can see that the cut stops just as the body curves away.
So, the solution is probably to extend the region you want to cut.  You can do this by just adding a line to your sketch:
Jeff
Jeff Strater
mandreko
Thanks. This is apparently what happens when you work as you're tired. That was way easier than I was making it.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
