Split and Combine Problem
zornzack
zornzack
I'm wondering what have i done wrong here? I could split the body out from the main body and i'm trying to combine it back and it seems to be giving me error. Is there anyway i could get around to fix this problem ?
PhilProcarioJr
@zornzack
Can you share your .f3d file so we can better see your problem and help you?
Phil Procario Jr.
Owner, Laser & CNC Creations
zornzack
Can i share my screen cast instead ? As you can see i did the same thing for the circle hole next to it and it worked.
zornzack
I think Fusion 360 still got lots of issue. I've manage to do split and combine in a different work around and it worked.
All i did was i copy the same main body. I cut from the first main body and i combine on the second copy and it worked.
I wonder why ... It was so crazy. It kept saying Boolean problem but with another body and slightly different steps to cut but same body, and it just worked.
