Solid loft that I cannot get to solve between the sketch and the end of the solid
jagSJMV8
Message 1 of 14
jagSJMV8
I have a similar problem with a solid loft that I cannot get to solve between the scetch and the end of the solid.
Why can I not just click the end of the solid and the outer circle of the scetch?
@jagSJMV8 A new thread was created and the title modified for this post to increase findability. Original: Loft not possible?  CGBenner
Accepted solutions (3)
Replies (13)
Message 2 of 14
TheCADWhisperer
@jagSJMV8
No islands in Loft.
Shell.
Undefined geometry should keep you awake at night.
Message 3 of 14
johnsonshiue
Hi! I believe you will need to do it in two steps. First, create the Loft for the outer profiles. Next, create a Loft Cut using inner profiles.
Many thanks!
Software Test Engineer
Message 4 of 14
jagSJMV8
Sorry  - I thought I had exported it.
I have tried with shell extrude and thickening but it does not solve the geometry
Message 5 of 14
TheCADWhisperer
@jagSJMV8
Start a new part file.
Start a new sketch on the top plane.
Sketch a Construction Circle as shown below...
Now sketch a Vertical Construction Line to the left of the Origin as shown below...
Now add a Midpoint Constraint between the vertical line and the Origin...
Now add a 36mm dimension to the Vertical Line.
What do you observe about the color of the sketch geometry after adding the dimension?
Message 6 of 14
jagSJMV8
Initially I have an orange dottet circle and a black vertical one
After pressing the coincident contraint I get black/black as you show - I have tried to do both a solid and surface extrude to it but cannot do the solid and surface only to the solid circle. I can surface extrude to inner and outer circle but not the solid - i include updated file3Y v4.png
Message 7 of 14
jagSJMV8
After this I applied a patch which have solved the issue, but I don't know why the solid loft does not work. I can finish it with surfaces, but I would like to know what I am misunderstanding or doing wrong.
Message 8 of 14
davebYYPCU
Using all of the last 2 sketches, solid Loft, as New Body.
Shell this new body 0.50 wall thickness.
Combine Join the two bodies.
Might help...
Message 9 of 14
jagSJMV8
Thanks Dave,
This method gives edges on the ID of protrution that does not get solved - I had similar results by edge shell and 0.5 thickness. What resolves right is to have two shell extrudes - ID and OD and then fill the space with a patch. I think I just have to accept that I don't understand why the solid does not work.
Message 10 of 14
davebYYPCU
What part of my file Loft - did not work?
I did not continue with your double surface lofts (deleted) was far more work, to then Patch both ends, and Stitch to Solid, before Combining the new body.
Might help...
Message 11 of 14
TheCADWhisperer
@jagSJMV8
You should always fully define your sketch geometry such that it turns black and shows lock symbols in browser.
See Attached file.
Message 12 of 14
jagSJMV8
Hi Dave,
The wall of the side tubes comes in at 45 degree which means that if the section analysis is done from the top it does not fit as the wall due to the angle is about 0.7 thick if projected on the XY plane but 0.5 on the other two planes
Message 13 of 14
TheCADWhisperer
Shell (at right time in history) returns consistent wall thickness.
If you want the tapered ends to be shelled too - change the history.
Message 14 of 14
johnsonshiue
Hi! There are multiple ways to do this. Here is a more compact design with a ball joint at the intersection. However, the pressure profile would be totally different than the original design .CFD Analysis is highly recommended.
Many thanks!
