snap sketch line to axis
Sungod3000
Sungod3000
I have a complex lofting setup where I interesected multiple planes with the axis through two planes construct.
Now Im trying to aline a sketch line with the axis but it wont snap and the point to point movement also doesnt recognize the axis as a target. I cant even draw a sketch line along the axis. Is there any way to solve that?
Cheers
jeff_strater
Hi @Sungod3000,
You have to first project the axis into the sketch using the sketch "Project" command:
That will create a sketch line that is the projection of the axis, and all sketch commands should recognize the projection
Jeff
Jeff Strater
Engineering Director
Sungod3000
yes i tried that but the only snapping i get is when i do point to point with a targeted projected point. and those are always a bit arbitrary since the the axis length can not be defined.
jeff_strater
You're correct - point to point move will only work with points (as its name implies), and the endpoints of an axis are arbitrary.
What I think you want to to, though is constrain a point in your sketch to the projected axis' line.
Here is screencast showing the basic idea:
Jeff
Jeff Strater
Sungod3000
weird I tried the coincident constraint first. but that seems to work indeed. ill try to replicate that thanks
TheCADWhisperer
P
Same as Convert Entities in SWx.
g-andresen
extensive vocabulary!
But it is not common here.
günther
