Smoothing a 3D scanned object
jaypalm1
jaypalm1
I had my custom insole scanned (see below). I would like to be able to modify the resulting object, but thus far have been unable to do so. Specifically, I would like to smooth out the top surface. I think most of the features on it are too small to have considerable affects when printing (our machine has a resolution of .05mm (it's a Taz 5), but ideally I would like to get a nicer looking model none the less. If possible, I would also like to be able to modify a bit of the shape to make the lip around the heel more accurate. Additionally, the model is very sluggish, which I think is largely due to the large number of triangles which make it up.
Any help would be much appreciated! Thank you!
I_Forge_KC
There are some great mesh smoothing tools in Meshmixer. I would start there.
K. Cornett
Generative Design Consultant / Trainer
jaypalm1
Great, thank you for the quick tip. I will check it out!
