Smooth transition between perpendicular wave surfaces
mateusconscious
mateusconscious
Hi everyone,
I am trying to make a smooth transition between two surfaces that have a wave texture. The surfaces are identical and I want to make a very smooth transition so a wave from one side matches the wave of the other side. I made the surfaces a bit small in the lateral edges, added a sketch above and under drew a rail and tried a loft command. I turned out better than my previous attempts but I am still not satisfied.
I added a picture of my problem and the file to this post.
Thanks for the help.
CGBenner
@mateusconscious
Hello, and welcome!  I've moved your post to this forum for greater visibility.  Good luck!
Chris Benner
TrippyLighting
This would be a candidate for the sheet metal tools. You'd create a panel wide enough to cover both sides and the radius and then bend that using the sheet metal tools.
mateusconscious
Thank you very much, that's exactly what I wanted.
Now I will try to reproduce by myself.
