Smooth connection between two bodies
dd1348
dd1348
I am trying to create a smooth transition between two bodies. I tried loft, but it only creates straight connection, not a curved one.
Thanks for any ideas!
g-andresen
Please share the file.
1. To recognize the positions of the bodies
2. Must the bodies remain separated or can they be united?
File > export > save as f3d on local device  > attach it to the next post.
günther
jeff_strater
you will likely have to create curves, and use them as rails in the loft.
Jeff Strater
Engineering Director
g-andresen
maybe this helps?
günther
dd1348
It seems like the easiest was to draw 3-point arc between edges on one side and then extrude it. Alternatively (and more precisely), one can draw two lines at edges coming from the corner and then use Sketch-Fillet to create a fillet between them with known radius. This way all properties are exactly same across multiple joints.
Thanks again for pointing me the right direction!
