Smooth a transition between two bodies
Buntobox
Message 1 of 14
Buntobox
Hi
I am trying to create a smoothed transition between the two bodies in this screenshot such that the sharp transition between the tapered section and the rest has a 1mm wide joining curve. I apologise if my terminology is a bit primitive. I have only been using Fusion 360 for twenty-four hours and other than that I have no experience of 3D CAD at all.
Alan
Edinburgh
Replies (13)
Message 2 of 14
TrippyLighting
Use a fillet.
‘If you are interested in learning fusion 360, downloading stuff to modify it is not the best way to learn it.
Message 3 of 14
TheCADWhisperer
Message 4 of 14
Buntobox
Absolutely. I have attached it here
Regards
Alan
Message 5 of 14
Buntobox
I've tried the fillet idea and it doesn't give me what I'm after. It takes the adjacent edges of both bodies and applies fillets to both, creating a round-edged groove between the two. And I haven't downloaded anything to modify. That design is mine, created from scratch.
Alan
Message 6 of 14
TheCADWhisperer
Are there any unresolved issues highlighted in yellow in your Timeline?
I recommend starting this design over from scratch making use of obvious symmetry about the origin.
I recommend that you Attach your file here after each and every step for guidance.
(Example: Create Sketch1 and Attach the file here.)
Message 7 of 14
TrippyLighting
My apologies, I had misinterpreted your first message.
Let me first answer your question:
You need to combine the two bodies into one before applying the fillet.
Otherwise, the filet tool is filleting the edges of each individual body. Modify-Combine(Join)
Now on to the other striking "features" in your design.
There are 16 warnings (yellow icons) in your timeline. Before continuing I would fix all of those, starting with the first one from the left. Otherwise, you risk your design becoming increasingly unstable and unpredictable.
Message 8 of 14
g-andresen
1. combine bodies
2. create fillets
Screencast
günther
Message 9 of 14
Buntobox
Thank you Guenther,that is very helpful and just what I needed!
Regards
Alan
Message 10 of 14
TheCADWhisperer
@Buntobox wrote:
... and just what I needed!
Not really.
Message 11 of 14
Buntobox
Hi @TrippyLighting
Thanks for the information. I seem to have cleared them all...I think.
Regards
Alan
Message 12 of 14
Buntobox
I don't understad what you mean. It did the job I needed it to.
Alan
Message 13 of 14
TrippyLighting
@Buntobox wrote:
Hi @TrippyLighting
Regards
Alan
Huh ? I still count 12 yellow icons in your screenshot.
Also, there are other conceptual and workflow related issues with your design.
If you want to learn how to drive a parametric CAD system like Fusion 360 properly then we need to take a few steps back to the very beginning.
For example, this design appears to be symmetric. So:
1. The design should be centered about an origin plane.
2. In effect that means you can only sketch half of the design, create 3D geometry and then mirror that.
3. Sketches for such technical companies should be fully defined (constrained and dimensioned). No blue lines  😉
Message 14 of 14
TheCADWhisperer
Do you want to learn how to do this correctly? (You will be amazed how much easier it is to do correctly.)
