Small Parameter Editor feature request?
I love Fusion 360. It's the only design software that I've used that makes any form of sense and it seemed to have adhered to my 30 min / 1 hour rule of software testing whereby if I can't workout the basics of using the software in 30 mins or 1 hour if the software is complex then it's not worth my time considering.
I love the parametric editing and it's here that my little feature request is aimed at.
So the above image is pretty standard and nothing special but because a lot of my designs keep having additions at a later stage I find that I can't group things nicely. An example of this is in this image. You'll see tablesawBottom, latheBottom, and scrollsawBottom all grouped together at the bottom of the image but there is one very similar entry called routershelfBottom which is about halfway up the list. It would be quite nice to be able to move these entries up and down the list. This is purely a visual thing of course but it would allow us to make grouping similar items together a lot easier. That being said being able to have folders in this list would make things easier to work with as well.
If I wanted to move this entry I would first have to delete this entry but in this case I can't because the other entries are actually referenced off this entry. I'd have to remove those entries, delete the first entry, then re-add the other entries.
While my projects are simple designs for woodworking it seems a bit weird that given the complexity awarded with parametric editing the easy grouping of parameters isn't part of the parameter editor.
jeff_strater
thanks for the post, @Anonymous .  I agree that the parameter dialog could use some work to make it more usable.  Grouping, sorting, searching, all would be very helpful.  For now, unfortunately, there is nothing that you can do to group parameters is to put them into the same sketch, or component.  I tend to use the "favorite" mechanism to pull out parameters that I want to reference often.  I also use User Parameters to help organizationally.
I do suspect that the parameter dialog will get an upgrade at some point, but there are no immediate plans to make any changes, unfortunately.
Jeff Strater
Engineering Director
