Sliding section analysis
jeffescott
Advisor Advisor
jeffescott
I created a path along a center line.
I created a sketch on this plane and created a section on the sketch.
The only way I can get the section to slide on the path is to edit the plane and pull it along.
Then hit okay then click on section then turn visibility off the on
Just gotta be a better way?
jhackney1972
If it helps, you do not have to cycle the Section Analysis to get it to update, just press Ctrl+B or Command + B to update the feature.
John Hackney, Retired
davebYYPCU
Edit the section Analysis?
Gives you the slide and rotate controls.
Can be totally independent of the originating plane you started it with.
Might help...
