Sliding mechanism with lock
ashjunkmail
ashjunkmail
Hello, I'm trying to design a holder for a Digital Dial indicator. The idea is to use it has a height gauge. Something like this but it holds the dial indicator. I have a requirement to allow the dial indicator to travel up and down, the lock in place to adjust for Higher or lower levels of measuring. I was thinkin of using a sliding dovetail for the travel, but I'm not sure how to add a locking feature into it so it stays in place?
etfrench
Do you want the display to have several different places where it's attached to the stand, or do you want to lock the scale in different positions?
ETFrench
ashjunkmail
Hello, Thanks for the reply, the Measuring Pin only has a 1 inch reach, so ideally I would like to have the Display slide upwards so that I can measure 3-5 inches
