Slider Assistance
Just need to get some NOOB assistance in fixing the slider action between two components The Support Arm Assy has to slide -3.5 and 3.5 from the current zero point. I have grounded the Primary PTU plate. Having difficulty determining the best way to make the slider joint function correctly. The offset plate should ride on the inside face of the lower channel. Is the key to select the lower face of the offset panel, then select the inner face of the lower channel. Help would be most appreciated
