Slicer for Fusion 360 "Mesh could not be imported"
Message 1 of 27
Greetings! the problem of importing files. If you import any (.stl or obj) file, an error occurs - "Mesh could not be imported". This happens on my two pc. (windows 7/64b). But on the laptop the program works stably (although it's less power). All visual c ++ and net framework libraries reinstalled. When importing using fusion 360 "File has failed to open on Slicer for Fusion 360, please try again", but on other computers these files are opened without problems.
really looking forward to your help.
Replies (26)
Message 2 of 27
TrippyLighting
I think we need to have a better understanding of what exact workflow you are following,.
I've worked with slicer only once, but it is my understanding that slicer creates meshes from solid bodies in Fusion 360.
Message 3 of 27
Hey Im just wondering if you got the problem fixed, I. have the same issue and I'm struggling to get a solution !
Message 4 of 27
Just to mention, I literally used Slicer for the past 5 months fine and then I updated my computer and I feel that it isn't letting me add any new STL or OBJ files.
Message 5 of 27
did you fixed your issue because i have the same.
i try to import a .obj model that i already imported before in slicer without any issue and i get the message "mesh could not be imported" and then it is causing Slicer to shut down...
Message 6 of 27
I found the solution ! looking to the old slicer 123d make known issues :
in my file PATH there was a special character (french character !) :
"C:\Users\guill\Desktop\sculpture cp\modèles 3d\untitled.obj"
I corrected it by removing the "è" and it works again !
Message 7 of 27
Hey thanks for quick reply! When I choose to look at the path it only shows me the folders that it has been placed in. It doesn't show me the file type ( OBJ ) for example. how do I see the full path and edit it. ?
 Thanks for your help
Message 8 of 27
Olá, sou brasileiro;
As pastas em que esta o arquivo .OBJ que deseja importar não podem conter nenhum caracter especial.
Ex.: Descktop/Papelão-Para-Esculturas/Ferrari/Ferrari.OBJ
Ex.: Descktop/Papelao-Para-Esculturas/Ferrari/Ferrari.OBJ
Apenas isso e problema resolvido 🙂
Message 9 of 27
Hello guys,
I found out this solution on this page https://parameterizing.wordpress.com/2016/11/28/import-failed-123d-make/ and it worked fine for me!
Basically what you have to do is just save your file on a pen drive and open the file from the pen.
Message 10 of 27
jmigneauxXAGKC
Observer
Observer
OMG so simple I didn't noticed it... I'm french too and yeah accents in your files names block Slicer to access to the right path I guess.
Thank you Guillaume !!! Merci ! 😄
Message 11 of 27
Merci beaucoup!!!!
Message 12 of 27
I can't belive it, works!! Thanks
Message 13 of 27
still not work for me. I put it in D:\ or in my USB disk, no non-English letters in the folder names at all. but the problem remains. this makes this software can only work with the built-in models.
why this?
Message 14 of 27
jodom4
Hey instantlx,
Slicer is currently in maintenance. Here's a post with more information on that, it might also have some helpful tips: https://forums.autodesk.com/t5/fusion-360-support/slicer-for-fusion-360-topics/td-p/8460043
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Message 15 of 27
Aveces es cuestión de ortografía , sugiero revisar la ortografía del nombre del archivo
Message 16 of 27
Gracias! Si, definitivamente mi carpeta fuente tenía la letra Ñ y ese era el problema
Message 17 of 27
Olá Yuri, gostaria muitooo de te agradecer, estava com esse problema, e nenhuma ajuda resolvia. Com apenas seu comentário tudo deu certo! Obrigada mesmo ahahaha
Message 18 of 27
Esta es la respuesta correcta!!
Message 19 of 27
me sirvio perfecto....
Message 20 of 27
It crashes even if you use _underscore in the filename, try to use only letters and digits.
