Slice Graphics Keyboard Shortcut
I've just started using Fusion 360. I have 8+ years of Inventor experience, and I use the "slice graphics" function in Inventor a lot where it is assigned the "F7" function key. Is it possible in 360 to get slice graphics assigned to F7? Unlike other functions, there is no "3 dot" next to slice in the sketch palette so I don't see how you can assign/modify a shortcut key.
Many thanks,
Paul
underwood.michael.c
To my knowledge, unlike inventor which I also use @ work...there is not a way to keyboard short cut. You can easily setup section views if your needing the slice a lot though and can easily toggle those on and off from the model tree.
Cheers
Michael - many thanks for reply.
I'll post something in the IdeaStation then!
Paul
