I have a wall that is 114" x 80" and I'm trying to design a slat wall. I would like to experiment with different width boards and different spacing. I'm familiar with the pattern function, but would like to be able to constrain it to the above dimensions and then play with the width of the slats and the space between them. Any suggestions.
Not much help but for inspiration check this out.https://lagunatools.com/videos/smartshop/#P3AGUdCnS04
Fast forward to the last 30 seconds or so.
This is really cool. Is there any way to "reverse" it? The smaller gaps are going to be dictated by some aluminum led channel that will go in some (20mm wide), and I want one dead center, so what I really need to determine is what width I need to cut the slats (~1-1.25 in.) and how many I will need.
I created the pattern symmetrically from the center line, with 57 in as the parameter. However, when I measure with the measure tool I get 114.778 in. Any idea why the discrepancy?
It's pretty straight forward to do.
ETFrench
