Sketches not generating 2d faces
noMLKDA
Message 1 of 8
noMLKDA
Not sure why the second rectangle doesn't "fill in". This has happened in other places in the project. Since the profiles aren't shaded in(aren't profiles) they can't be used to extrude etc.
Replies (7)
Message 2 of 8
g-andresen
Please share the file.
Then you could check if the profile is not closed.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Message 3 of 8
TheCADWhisperer
2D sketch or is it really 3D sketch?
Message 4 of 8
noMLKDA
That's kinda what I was thinking but I'm not sure why the first rectangle became a profile.
Message 5 of 8
noMLKDA
There's the file. Sketch 14 is the one this is regarding, however Sketch 2 has the same problem.  Thanks for the help.
Message 6 of 8
mango.freund
hello, in sketch 2 "show profile" was switched off. in skestch 14 i removed projected links and the profile was immediately visible. all lines blue!!! not good.               greetings mango
Message 7 of 8
TheCADWhisperer
@noMLKDA wrote:
1.  Sketch 14 is the one this is regarding, however
2.Sketch 2 has the same problem.  Thanks for the help.
1. Turn Projected to Construction and close the profiles.
2. Turn on Shaded Profiles.
Message 8 of 8
noMLKDA
Thank you for the help people. I appreciate you taking the time to figure this out.
