Hello all,
I'm very new to Fusion 360 so hopefully my issue is something an experienced eye can catch quickly.
The problem I'm having is with rotating a copy+pasted sketch about the Z-axis based on user defined parameters. I can set the sketch rotation once upon its creation using said parameters, but if I update the parameters afterwards, the sketch rotation does not change.
My trouble shooting of this issue has involved the following work flow:
The sketch above is copy+pasted from the one below. Rotation is not yet applied.
Top-Down View: The "Move" command is set up like so, rotation of Sketch Objects about the Z-axis applied using user defined parameters.
Move command is completed, but does not show up in the design timeline. Updating the User Parameters does not change rotation the angle after creation.
I'm assuming there's a much easier way to go about this and any input would be greatly appreciated.
Happy Holidays
