Sketch Tutorial
Sketch Tutorial
Sketch Tutorial
Can anyone point me to a sketch tutorial that explains projecting and converting lines from and to construction lines. I'm seeing magenta lines, orange dotted lines, green dotted and green solid lines and of course white lines.. I can't find a reference that explains them, what Fix/unfix is etc.
Mike.Zhang
Sketch Project allows you to use other geometry's shape lines as sketch input when you create a sketch, it will save your time when you create complex models.
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Mike.Zhang
Mike.Zhang
SQA Engineer
Autodesk, Inc.
laughingcreek
origonal OP was also asking what the colors meant.  No mention so far of that.  Is there a reference some where in the documentation?
O.Tan
Can you provide us a screenshot of the lines you're seeing?
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
innovatenate
Autodesk Support
Autodesk Support
magenta - projected sketch entities - sketch entities that have been projected from other sketch entities or 3D geometry into the active sketch (these entities are fixed in space, you can select them > right click > select Break Link to remove the association with the originating goemetry
orange dotted - construction sketch entities - entities that will not be used to create 3D geometry but may help the sketch in some way (e.g. a line to mirror across) You can modify  by selecting normal/construction from the right click menu
green dotted - fixed construction sketch entity - construction sketch entity with a fixed constraint applied to it so that it has 0 degrees of freedom and will not move
green - fixed sketch entity - same as above
white -  normal entities or pre-highlighted or pre-selected entities (when your cursor is hovering over sketch entities)
Below is a Screencast I've made for another post regarding the sketch environment that may help.
I hope this helps. Let me know if you have any questions.
Nathan Chandler
Principal Specialist
