sketch solver problem
sketch solver problem. in the video, you will see the remaining unconstrained entities in blue. they can be fully constrain by the radius or the angle. however, only dimensioning the angle will fully constrain it. trying to put the radius dimension on, the solver is not able to solve it.
http://autode.sk/1TERtAe
jiang_peng
I am sorry you having that issue. It looks definitely a bad bug.
However it's too hard to locate the root issue just from the video. Could you please share the design to me? That helps us a lot to improve our sketch engine. Please following this guide to share:
http://fusion360.autodesk.com/learning/learning.html?guid=GUID-1500941F-6EB7-4058-8CD9-7642DEA250E7
My email address: Jiang.Peng@autodesk.com.
Have you tried turning off the option?
Preferences -> Preview -> Sketch - Color sketch geometry based on constraint status
Thanks for reporting this!
jiang_peng
The bug is logged as FUS-23392.
