Sketch selection problem
geryggTL98L
Message 1 of 27
geryggTL98L
I made an .SVG from a logo on Illustrator, but when I import it to Fusion I cannot select only the fill part from it, it selects it all. I'm new to 3d and no idea how to solve this.
Screen Shot 2020-07-10 at 13.18.18.pngScreen Shot 2020-07-10 at 13.21.40.png
Thanks!!
Replies (26)
Message 21 of 27
davebYYPCU
Sketch is fine, 14 spline curves, moves as a unit, not on the Origin, and not constrained.
Copies and scales.
Might help....
Message 22 of 27
MaxHugen
Were you able to edit the spline points themselves, such as reposition them, modify the curves etc?
Message 23 of 27
davebYYPCU
Yes and no, can click drag the splines, and not the points, likely due to being imported.
Message 24 of 27
MaxHugen
That's interesting.
In Edit view, I can select a point but it doesn't display the splines.
Message 25 of 27
g-andresen
Hi.
1. Please start a new thread for such questions in the future.
2. Even if the segment is called a spline, it does not mean that it is editable like a spline.
My Tip:
1. fix the contour
2. create a new spline in a new sketch. (only a few control points!!)
Screencast
günther
Message 26 of 27
davebYYPCU
More like weird.  I have no experience with control point splines.
These splines are control point, and select > Right click, you can display the control point frame.  The intermediate points are editable but the start and finish point will remain unmovable.
Message 27 of 27
g-andresen
If you have activated the Control frames complett, you create tangential conditions and then edit the contour.
After you have done this a few times, you´ll create the spline from scratch.
günther
