Sketch seems to ignore curve
Message 1 of 10
I have been trying to create a puzzle today and I came across a problem where sometime these edge pieces seem to ignore a line, as far as I can tell, all the lines are connected and the sections should be separate. I can place a line to see it seems to not like the bottom-right corner for whatever reason, the only solution I have found is to delete the last segment of the curve and re-draw it by hand, I will do that but I would rather know an easier fix as I will be making lots of these...
Thanks for any help...
Replies (9)
Message 2 of 10
laughingcreek
Are thee imported, or did you draw them in fusion?
Message 3 of 10
It is imported from a DXF, however the lines it doesn't ignore were created with the offset tool
Message 4 of 10
TheCADWhisperer
@Anonymous
Can you File>Export and the Attach then *.f3d file here?
Message 5 of 10
Here it is, Just note that I have fixed some of them by drawing them with a spline
Message 6 of 10
TheCADWhisperer
I can get a closed boundary by Projecting the edges into a new sketch.
But the one edge causing the issue is not an orthogonal projection.
I suspect that there was a Z component in the original dxf.
Can you attach the original dxf here?
Message 7 of 10
I had used a plugin for Inkscape so I guess thats what caused it.
Message 8 of 10
laughingcreek
I don't know if it's bad source DXF's, or if it's the process fusion uses to import them, but importing curves into fusion has always been problematic.  I think it's fusion's import process.  It always seems hit or miss on whether you can use imported curves directly without rebuilding.  I ALWAYS rebuild if I'm going to do any surfacing.
Message 9 of 10
HughesTooling
There is something wrong with the splines at the ends. I opened your dxf in Rhino and tried to extend those splines and can only extend one end, all other curves in the file work fine. I found if I zoom in a long way it will extend but it goes a bit haywire and doubles back on itself. Found the same in fusion, if you copy one of those end curves away from the rest, draw a circle around it, it will only extend from one end, other splines in the file extend both ends.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 10 of 10
HughesTooling
Here's the problem, there are 2 points stacked at one end of the splines at the ends.
Mark
Mark Hughes
