Sketch revolve looks weird, why?
ilan1204
ilan1204
hi
i am creating a sketch and have put all dimensions and constraints so all lines are black and i also have a lock on the sketch profile but why are the radius so weird when i do revolve?
is this normal or am i doing something wrong?
HughesTooling
Can you share the design? This might be just a display problem, have you tried changing the Display Detail Control,
and setting it to fixed and High. I have noticed section seems to lower the resolution as well. You should find the actual model is accurate to the sketch but the display mesh might not look good.
Mark Hughes
Owner, Hughes Tooling
ilan1204
thanks a lot, now it looks much better 😊
