Sketch / Point driven pattern
stefanvanderheijden
Observer Observer
stefanvanderheijden
Observer
Observer
Hi all,
Am I correct in concluding (after looking for it) that Fusion doesn't offer a sketch driven pattern (like Solidworks)? I'd really like such a pattern feature.
Alternatively, I'd really like it if move/copy > Point to Point would allow me to select multiple Target Points, that would in practise result in the same functionality.
typical situation where I'd like point-driven pattern (would be faster then mirroring the parts).
Allowing me to select multiple Target Points (and thereby creating multiple copies) would results in the same behaviour.
EDIT: A better use case example (not symmetric):
A wooden block with holes in it (driven by point-driven-holes).
One hole has a dowel in it, I want the dowel component in the other holes.
Thanks for the great product!
Stefan
TrippyLighting
@stefanvanderheijden wrote:
Hi all,
Unfortunately, yes!
I've asked for this at least 10 years ago!
stefanvanderheijden
Observer
Observer
There really are situations where point-driven pattern is the only elegant solution 😪
btw, my example isn't really the best as the part still is mirrored along X and Y.
TheCADWhisperer
Can you File>Export your *.f3d file to your local drive and then Attach it here to a Reply for experimentation with various techniques.
stefanvanderheijden
Observer
Observer
I've added and example usecase to the original post 🙂
laughingcreek
duplicate with joints is probably the best option here-
(view in My Videos)
