Message 1 of 11
I've noticed this problem several times and it can become quite frustrating when you have a complex model. This issue crops up every time I use the "Create Sketch" command where I want to generate a sketch from a planar surface on a solid model. The command itself works fine but the resultant sketch has no outline. I have scoured all of the menus relating to the sketch but nothing will let the outline display. The sketch can be used to extrude or sweep or any other normal function/modifier as normal, just no outline.
