Sketch on view cut
Sketch on view cut
Sketch on view cut
Hello
I'm moving from Solidworks to Fusion 360.
I used to sketch on cut 3D views.
I can not find this option on Fusion 360.
Can you tell me if this is possible?
Similarly, I do not find the exploded view tool, nor the ability to anchor sketches on hidden features.
Thank you
aaronkcap
There might be a better way to do this but the way that I found work is to go to the inspect tab and do a sectional analysis then create an offset plane.
It's just the solution I was waiting for.
Thank you very much
aaronkcap
No problem
I was searching for that and I found the slice option on sketch pallet!!)
