I am drawing a tool holder that has 22 thermomiter shaped slots ( slot with bulb on one end) the patern will be two rows of 11.
The slot width, end radius, and center to center distance of arcs are all constant.
The bulb ends are all differant radius.
I can't seem to figure out a way to pattern this, if i pattern one size then break the pattern so i can resize the bulb end i have all the geometry but lose all the constraints and dimentions, is there a way to automaticly add constraints?
I want a fully definded sketch that i can export to my plasma table.
