Sketch etc features are shown after extrustion
Hey guys,
I'm just learning this on the go and I've stumbled across something that I can't quite seem to fix. Everytime I make an extruded model and go back to edit the sketch of such model, the sketch then shows up on the 3D model afterwards. Does anyone know of a way to get rid of this? And will this show up on the final render? I've attached an image so you guys can see what I mean. If you'd like me to upload my assembly of this, I can do that too, but I figured this is a rather common issue.
jeff_strater
How it's supposed to work is:  When you consume a sketch with a feature, Fusion makes that sketch invisible.  When you edit the sketch, Fusion will make it visible for the edit, then turn it back off when you exit the sketch.
However, if you have ever manually made the sketch visible (using the light bulb), then Fusion recognizes that as the intended state of the sketch, so it will not hide it when you exit the sketch.  So, try turning off the sketch using the light bulb icon, then editing the sketch again, to see if you see the same thing happening.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
I did just that and it worked! Thanks!
