sketch dimensions
sketch dimensions
dlynch_01
sketch dimensions
dlynch_01
I am sorry to ask as I am sure I am doing something wrong.
Very new to this and going thru the lessons.  When I uploaded the saw and scaled it all ok. Now trying to draw the trigger. When I sketch dimension it displays in Deg and not MM. I can not see a way to correct this. The two line are parallel.
Thank You
davebYYPCU
If Sketch dimension displays in Deg and two line are parallel - one statement is not true
The Sketch dimension will display mm when the two lines are parallel.
I would check again.
TheCADWhisperer
File >Export and then Attach your *.f3d file here.
dlynch_01
Here is the file.
TheCADWhisperer
Delete angle dimension.
Add Parallel Constraint.
Add Dimension.
If you had extended those lines - you would find that they meet at a point 1.567E+04 down the road.
dlynch_01
THANK YOU!
