The logic is that the radius is half the diameter 😉
Kidding aside, why would this matter ?
If drawing a circle manually I would determine the radius and draw from the centre, this seems to be the logic behind drawing a polygon eg a hexagon.
If drawing a hexagon the usual measurement is across flats (diameter).
The menu option Sketch | Circle | Center Diameter circle gives a pop up description " Creates a circle using a centre point and radius. Select to define the center point then specify the radius."
It is just confusing until one gets used to it. Even the developers / documenters are confused.
Hi OldNGrey,
Good catch for the description issue "Creates a circle using a centre point and radius. Select to define the center point then specify the radius." This is indeed confused to the users.
The development team will change the description to "Creates a circle using a centre point and diameter. Select to define the center point then specify the diameter."
Daniel Huang
