Simulations basics
Simulations basics
steveVLDE4
Message 1 of 8
Simulations basics
steveVLDE4
Hi All, I'm planning on doing some simulations on a DIY drone design. I want to do stress simulations and modal, and am trying to learn as much as I can before taking up my 14 day extension demo, so I can decide if its worth investing in for my small business.
I had a few questions:
- When simulating a multi part model which is screwed together in reality - do I use rigid joints in the design space or constraints in the simulation space. And should I include screws or just make a rigid joint between components?
- If I want to simulate the stress of a part in a crash or the whole model - is static simulation sufficient or does it need an event simulation?
- With the modal simulation - is it possible to use the simulation to judge the amplitude of the resonant modes or just the frequencies?
Replies (7)
Message 2 of 8
Drewpan
I don't know the exact rules, but if you are using the software and making less than $1000? it is considered
personal use and you might be able to use the free version. There are some things with the free version it
will not do but maybe you can just pay for those "services". Again, I am not sure but this may make your
decision easier.
If you haven't already, do the simulation tutorials in the official Fusion Documentation for tips on how to do
simulations. The official AutoDesk YouTube channel also has good tutorials. I don't have enough experience
to help with your specific questions but hopefully these pointers will help.
Cheers
Andrew
Message 3 of 8
TheCADWhisperer
No.
Linear elastic static stress analysis is limited to within the elastic stress range. (Not a measure of fracture).
Limited to materials that are not relatively brittle or “rubbery”.
Limited to non-extreme geometry aspect ratios (no relatively long thin geometry).
Slowly applied loads (no impact loading).
Limited to isotropic materials.
Message 4 of 8
steveVLDE4
thanks. Im using CFRP (which is also a problem because it seems to be isotropic and the carbon sheet we use is anisotrpoic)....so you are saying that it can't simulate a break but only the 'elastic' stress range?
Therefore yes - I need to use event simulation ideally?
Message 5 of 8
steveVLDE4
I have a paid license, because I crossed that threshold but its still a hobby business...I would have loved to get it free but they told me those were the options...
The thing that is frustrating is you need credits to use the modal and event simulations, so I'd need to either trigger my 14 day demo use, or pay $300 for a batch of tokens. Hence Im trying to organise my knowledge before doing one of those...
Message 6 of 8
TheCADWhisperer
@steveVLDE4 wrote:
 Hence I'm trying to organize my knowledge before...
This would be a lofty endeavor.  I would guess at least a year of effort.
Message 7 of 8
steveVLDE4
I've found the resources in the Autodesk University which is helping....otherwise it seems like info is thin on the ground...
Message 8 of 8
jeremy_camper
I hope it's OK I'm asking on this post you just seem very knowledgeable on fusions simulation
Say if you have a quick connect on a tube can you test push on and blow off pressures
