Simulation
Simulation
MrRBall
Simulation
MrRBall
Hi, On Fusion simulations on my Macbook the attached screen comes up when I try to select a new simulation study. I cannot scroll across and choose the other options e.g. Shape Optimisation... Any ideas?
shigeaki.k
Hello @MrRBall,
this was a known issue with the previous version (2.0.26xx) of Fusion 360 with the latest MacOS 10.12.3. Could you check what version you are currently on and what version of OS you are using?
If you are not using the latest version of Fusion 360, could you make sure that you are connected to the internet, close and reopen the app. to update it to the latest version?
Shigeaki K.
Shigeaki K.
Technical Support Specialist
サポートとラーニング | Support & Learning
shekar_sub
Andrew Sears suggested a workaround
https://forums.autodesk.com/t5/design-validate-document/create-new-simulation-bug/m-p/6883978. Hope this helps. Thanks
shekar
shigeaki.k
Hello @MrRBall,
could I reconfirm that the problem was solved and what version of OS you are using. I am asking as our Macbook (see figure below) seems to have solved the problem by updating Fusion 360 to the latest version but in another forum updating to Fusion 360 2.0.2727 did not solve the problem.
Shigeaki K
Shigeaki K.
