Simulation report question
I have a question regarding simulation reports:
Other than creating a web page with all the simulation results is it possible to output results (either all or selected results) to a MS Word document or similar, so they can be edited?
Also, are there plans in the near future to have shell elements to enable analysis for sheet metal parts
Andy Barnes
Hi Fusion Team,
Any feedback on this question?
Andy Barnes
Shell elements would be great. They mentioned it was in work and then put on hold last time this was asked. Hopefully its resumed.
As far as the report...I've never seen anyone use the report from any FEA package in the business world because its easier and more readable to do it yourself. Is this normal practice at your employer?
If it were possible to output the report as a Word document it would be easier to edit or, copy and paste the results and setting. The web page output is a bit limiting i.e. to extract sections of the data you have to use cut and paste and you can't edit any of the text.
