Simulation of alminium /glass roof.
Hello Comunity 🙂
My name is Lukas. I'm using Fusion for about 3 years now and wanted to try some more advanced functions but hit a brick wall with that. I'm designing aluminium profiles that are extruded to build diferent constructions.
My questions are:
1. Is it possible to do simulation of snow load on whole roof which is about 120kg per square meter?
I tried many different aproaches but wasn't able to set all parameters to even start simulation.
I manage to do simulation for single roof beam but that doesn't tell me enough and I was able to do that by adding some fixed support points which are not very realistic.
2. Second is shape optimization. I can't do optimization for cross section of this extruded profiles. The resoult is always to remove material in 1/3rd of the beam. I need to optimize cross section so when profile is extruded on press ti's the same in all it's lenght (for example 6m).
Here's a link for my example (it can be downloaded) https://a360.co/3ZWBofX
I would very much apretiate every single tip!
Thank you in advance!
Oh and sorry for my english ;-/
