Simulation Modelling Error (Graphics card problem?)
brianriordan
brianriordan
Please see attached files.  I can only view my whole model from certain angles as parts of the model disappear as I rotate the model.  The parts that disappear, also make the mesh look like a surface, and not a solid- not sure what that means.
josef.kucera
Hi Brian,
we are sorry about the issue with viewing simulations. Could you send us information about your Graphic card and system you are running?
Kind Regards,
Josef
Josef Kucera
Fusion QA
brianriordan
Josef,
I went home and tried to use my home computer and had the same problem.
My home computer is running on an Intel(R) Core(TM) i7-5820k CPU @3.3GHz,
32GB ram, 64-bit operating system, with an Nvidia GeForce GTX 970 w/ 4GB
ram.
Brian Riordan
979-218-8009 (Mobile)
Riordan.brian@gmail.com
tomas.bujnoch
hello brianriordan,
1. Clipped results issue has been already fixed in our repository, so the fix for that will appear in one of the next Fusion updates or in November release.
2. Current build doesn't contain solid mesh - only the surface results are available. Solid mesh is expected to come out with November release.
Pavel_Holecek
the visualization problem was fixed in the lattest update 2.0.1708 (which was released yesterday).
Let me know if you have any other issues
Pavel
Pavel Holecek
Autodesk QA team
