I am trying to run a simulation on some parts I have designed, I have worked through the meshing errors with the help of another user, but have come across Singularity errors when i try and solve the simulation. I have searched the forums and tried a few different things to see if it helps but it doesn't.
I have attached a snip of the errors, and have attached the whole error file and part file if somebody is able to have a look and give me some assistance?
Basically the parts are used as engine mounts on an engine block. I have removed all unneeded parts from the simulation using the simplify function.
Thanks for your help in advance.
George
"Error: SINGULARITY DETECTED AT GRID 898657 COMPONENT 1
Cause : A singularity has been detected in the stiffness matrix during decomposition.
Action : Investigate the degree of freedom at which the singularity occurred for a lack of
stiffness. Also, check your model for a lack of constraint."
