Simulation CFD Launch Button Missing from Fusion Ribbon?
I just installed 2015 Simulation Mechanical, CFD and 2013 R1 Inventor Fusion.
In the "simulation" panel in Fusion I have a button to launch Simulation Mechanical but there is no button for Simulation CFD.
I uninstalled Fusion and reinstalled it - again Fusion did not seem to find CFD.
Is there a way to manually add CFD or a way to direct Fusion to find Simulation CFD so it can be added to the Simulation Panel?
Greg...
hartogj
Hi Greg
If you installed Fusion 2013 R1 after Simulation CFD 2015, it may be helpful to run SimCFDConfig.exe to connect them together.
Can you try running that executable from C:\Program Files\Autodesk\Simulation CFD 2015, making sure "Fusion 2013 R1" is checked, and completing the process?
Jon
Jon den Hartog
Product Manager
Hi John,
Thank you - solution worked perfectly!
Kind regards,
Greg...
