Simulation add material bug
macmanpb
macmanpb
If you add material to favorites the category is undefined.
josef.kucera
Hi macmanpb,
good catch. I will report it internally to adress this issue.
Thank you.
Best regards,
Josef
Josef Kucera
Fusion QA
Sophia9911
Hi macmanpb,
Thanks for your question.
You can create category under library to group your materials, for example, you can create a 'Metal' category under Favorite and move your material under 'Favorite > Metal'.  If a material move to Favorite library root, it will show as 'uncategorized' as design.
For the type, it is to tag the material usage by default, and you can freely change it to different choice like 'wood' to re-tag it if you need.
Sophia
