Simple Sketck - Midpoint Snap- Where?
admaiora
Mentor Mentor
admaiora
Can you help in explaining me  this?
Am i missing something?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
HughesTooling
Odd that that doesn't work but if you use the midpoint constraint it will. Select the Midpoint constraint from the sketch palette, pick the midpoint on the first line then just pick anywhere on the second line.
Mark
Mark Hughes
Owner, Hughes Tooling
admaiora
Thank you Mark,
that helped. Not so natural. Not so obvious. Not so necessary (my opinion) new midpoint constraint
Is there any reason anyway why the most simple way is not available?
I want to make coincident two points > Enter command coincident > click the two points
Admaiora
promm
@admaiora,
What you are experiencing is a bug that had been recently found.  It has to deal with the center points of two lines, the team is working towards a solution.  I found that you can apply a vertical/horizontal constraint followed by a coincidence constraint to the two center points and it will work.
cheers,
Mike Prom
admaiora
Thank you Mike!
And thank you Mike and all the Fusion team for this ongoing effort to make Fusion better!
Admaiora
